I don’t know if you’re aware, but with your intersections, you’ve created enough route options for almost exactly a metric century.
Alongside the “Flat”, “Hills”, “Group”, and “Surprise Me” intersection preferences, it would be great if you added a “Simnett Century” option. Ok… Call it “Metric Century” if you prefer…
It would probably only need to default the Intersection options to a specific pre-defined order. And obviously give someone a “Simnett Century” Achievement for completing it… Ok… Maybe not that either…
This is a serious and sensible enhancement suggestion though. Here is the detail:
Starting at the Just Ride point. If you ride every variation of a loop with the new intersections on Watopia in a row, it’s 98.65k (61.3 miles)
If you add a climb up and down the KOM at the end, that’s exactly 100k.
Not a bad way to make an imperial century more interesting…
I consider a “loop variation” to be one where you don’t go over the same bit of road in the same direction twice before crossing the start/finish line again. If you do them in a sensible order then you don’t need to use the Turn Round button to complete this ride.
The route that I did is this:
- Loop 1: Forward with underwater section then through to finish forward (Left, Left)
- Loop 2: Forward with underwater section then up KOM to finish reverse (Left, Right, Left)
- Loop 3: Reverse with underwater section then through to finish reverse (Right, Right)
- Loop 4: Reverse with underwater section then up KOM to finish forward (Right, Left, Right)
- Loop 5: Forward up KOM and then through to finish forward (Right, Right)
- Loop 6: Forward up KOM and then through underwater section to finish reverse (Right, Left, Right)
- Loop 7: Reverse up KOM and then to finish reverse (Left, Left)
- Loop 8: Reverse up KOM and then through underwater section to finish forward (Left, Right, Left)
Would probably be sensible to check that I’ve listed those loops and directly correctly - human error and all that.
If you want to see this, as a ride, this is my activity on Strava. Just look at the first 100k. I did a little bit extra as I wanted 70 miles today.
https://www.strava.com/activities/459324237
Thanks,
Mark
