Power Freezes
anybody have power freezes, too?
After 10 minutes or less, or more (not reproducebale)  the power freeze on the UI see te image:
Zwiftalizer says all OK:
I have the data also on my Mobile so the power change there, but not in zwift!?
I think my stick is broken, after the next train i had much ANT+ searches, i have ordered a new one and will see.
my Firmware was sending wrong data, so that the power was freezing, it looks like when a division / 0 is happen, or not a number is reaching the stick, the data freeze.
I solve this my own, but could be that some vendors have that issue, too?
It is not  a Zwift problem it is a device problem.
I really love Zwift and hope that much updates for more maps coming soon!
Keep up the good work!
I have had this happen also. The power will freeze at a specific reading and the only way I have found to fix it is to unplug the trainer. It does not happen often - about the times in 25 rides this far. How did you resolve this?
Sorry, that should have read 3 times in 25 rides. It is not reproduceable.
I have access to my ant+ source and had reduce to 4 request per seconds instead of 8
Also i have changed the extension cable ANT+ Stick and Trainer device are now 25 centimeter from each other.
I dont change anything else. May be you need a firmware upgrade?
If you like you can check on zwiftalyzer for more Info and help:
https://zwiftalizer.com/
Ride on!
I am pretty sure my firmware is up to date but I will double check. I also keep my ANT stick close to my trainer with an extension cable. What an I looking for in the zwiftalyzer analysis? And how do I find my ANT source?
I suggest you post your setup with screenshots on facebook in group zwift riders:
https://www.facebook.com/groups/zwiftriders/
There are fantastic people and offer great help. I am also there :slight_smile:
I have access to my “source code” so i can change things that you normally cant.
I have build my own power meter.
Good luck
Good suggestion. Thank you very much for your help, I appreciate it.
