Polar Verity Sense connects on Windows 11 but sends no heart-rate data in Zwift — firmware 3.0.16
  1. options are on
  2. phone BT off, Garmin watch switched off
  3. can’t find a specific setting that you described (the Default/Advanced)
  4. tried on a different (recent) gamingcomputer instead of my laptop: sensor NOT detected. So now on 3 PCs, an old W10 laptop (*), a 2023 W11 laptop and a 2026 W11 desktop the sensor will not be detected.
    I just have the sensor switched on, tried switching on/off and switching the different modes, no difference. I also did a factory reset, had a very hard time to reconnect the sensor in the Polar app (very very unintuitive app if you ask me)
How can I find out what specific BT hardware my computers use?
W11 laptop 2023: Intel(R) Wireless Bluetooth(R), driver 23.80.0.3
W11 desktop 2026: Intel(R) Wireless Bluetooth(R), driver 24.10.0.4
Both PC report the drivers to be the latest
Checked when I bought the sensor, but sadly I’m 4 days over the returnpolicy. It will be a long time that I will buy polarhardware again. Never had any issue for years with a Garmin HR strap (untill it broke) and apparently Polar is not in a hurry seeing this issue’s age?
(*) I used that old W10 laptop for Zwift before, but I did a reinstall of windows only to find out HP has deleted all drivers for that laptop. So can’t use that anymore since certain hardwaredrivers are not available anymore.
Laptop works though, although it won’t connect with my Ant+ dongle due to USB issues. BT works though; I can pair my Garmin, My Elite Suito-T trainer, but not the polar sensor.
Hi StefKe,
Thanks for the detailed information. I completely understand your frustration, especially after testing the sensor on three different computers.
Your situation is slightly different from mine. In my case, Windows 11 and Zwift detected the Polar Verity Sense, but the heart rate was not transmitted correctly. In your case, Windows cannot discover or pair with the sensor at all.
Before giving up, I would suggest a few additional checks:
  1. Check Bluetooth visibility in Polar Flow
    Open Polar Flow, connect your Verity Sense and go to its device settings.
    Make sure:
    “Heart rate visible to all” is enabled.
    “2 Bluetooth devices” is enabled.
    You could also try toggling the dual Bluetooth setting and testing again.
  2. Check the sensor’s operating mode
    Make sure the Verity Sense is running in heart rate mode, indicated by the green LED next to the heart symbol.
    Close Zwift and Polar Flow completely, keep Bluetooth disabled on your phone and Garmin watch, and try discovering the sensor again.
    Regarding the Windows “Default/Advanced” Bluetooth discovery setting I mentioned earlier: if that option is not available on your Windows version, simply skip that step.
  3. Try a different Bluetooth adapter
    Since both your Windows 11 computers use Intel Bluetooth adapters, it would be interesting to test a separate USB Bluetooth adapter, preferably using a different chipset.
    If you can borrow one, temporarily disable the internal Bluetooth adapter in Device Manager before testing.
  4. Identify your Bluetooth hardware
    You can find additional information here:
    Device Manager → Bluetooth → Intel(R) Wireless Bluetooth(R) → Properties → Details → Hardware IDs.
    This will show the hardware identifiers of your Bluetooth adapter.
  5. Contact Polar support
    Considering that you have reproduced this problem on three computers, I strongly recommend contacting Polar support directly.
    Explain that:
    Your Verity Sense uses firmware 3.0.16.
    Bluetooth discovery fails on three different PCs.
    The sensor works correctly with ANT+ and your Garmin.
    You have already performed a factory reset.
    Even though your retailer’s return period has expired, you may still be entitled to warranty support.
    I experienced serious Bluetooth problems with firmware 3.0.16 myself, but we cannot yet confirm that the firmware is responsible for your particular issue.
    Please let us know what happens after checking the “Heart rate visible to all” setting.
    I would really like to help you get this working.
    Best regards,
    Jordi_Riu_Popito
thank you for your efforts.
Yesterday evening late at some point I tried again, without really doing anything “new” or different, but now my sensor was detected on both my laptops. Going to Zwift now makes the sensor available with a signal.
Have not been able to test combined with my trainer, I want to do a test (+workout) tomorrow.
To be honest I don’t know why it suddenly worked. Perhaps the factory reset, but immediatly after that it wouldn’t work at first. Now it seems to be solved (in the sense that the workaround with pairing in Windows before Zwift works).
I will let you know if I can actually use it in Zwift during a session
Hi StefKe,
That’s great news! I’m really glad your Polar Verity Sense is now being detected by both laptops and that Zwift is finally receiving a heart-rate signal. Thanks for keeping us updated, and well done for sticking with all the troubleshooting.
It’s possible that the factory reset helped, although we can’t say for certain, especially since the sensor didn’t work immediately afterward. The fact that pairing it with Windows before opening Zwift now works is a useful finding for others experiencing this issue with firmware 3.0.16.
The final test will be to check whether the heart-rate signal remains stable throughout a Zwift workout with your trainer connected. Please let us know how it goes, and whether you notice any dropouts.
Fingers crossed that everything is finally working properly. Enjoy your ride!
Jordi Riu Popito
Same here.
I thought it was a good idea to update my P V S with new firmware.
In the past it was no big deal. But tjis time things got broke like you all already said.
Thanks for the work around. Will test it later, if it works for me.
The totally very good product is now not working properly.
It comes to my mind that DCR wrote about it some years ago and in order to prevent myself to upgrade firmware on PVS, it quit my account on Polar. But i lost that sticky notes somewhere deep in my rotten brain.
If the work around is not convinient enough for me, which other arm heart beat solutions are good enough? Wahoo, garmin?
Hi Victor,
Thanks for sharing your experience. It’s frustrating to see another Polar Verity Sense user running into problems after a firmware update, especially when the sensor worked well before.
Before replacing it, I’d suggest trying the Windows 11 workaround described above:
Completely close Zwift.
Temporarily turn off Bluetooth on your phone and any other devices that might connect to the Verity Sense.
Pair the sensor in Windows Bluetooth settings first.
Then open Zwift and connect it as your heart-rate monitor.
This restored the heart-rate signal in my case.
StefKe has also reported that the sensor is now detected on two laptops after further attempts and a factory reset, although we’re still waiting to hear whether it stays stable during a complete Zwift workout.
So it’s a promising workaround, not yet a guaranteed fix.
If you’d rather switch to another optical armband, two options worth investigating are the Wahoo TICKR FIT (Bluetooth and ANT+) and the COROS Heart Rate Monitor (Bluetooth).
Garmin offers good heart-rate monitors too, such as the HRM 200, but that’s a chest strap rather than an optical armband.
I’d check compatibility with your own setup before buying anything.
Could you let us know whether the workaround works for you, and which firmware version your Verity Sense is running?
Every additional report helps us narrow down the problem.
Best regards,
Jordi Riu Popito
Hi Jordi,
Current firmware. Your described Workaround worked for me today.
Yesterday after all the trouble i switched the BT connections to ZCA and that worked as well.
Before that firmware upgrade i was on 2.x FW. The power on order didn’t matter at all.
I will try that coros arm strap, that seems good for me. No power on button and 3 BT connections in parallel.
Most of the time i use zwift on linux with ZCA as BT brigde for kickr, climb, headwind, HR, play and other stuff.
But sometimes that podman build is outdated or lacks on startup. Then i switch back to w11 and use thebpc as BT host.
So for now startup order is to switch on PVS at first and then all the other electronics. Or use ZCA all the time. Both works for me. I will give back feedback on that coros thing.
Hi Victor,
Thank you for testing the workaround and sharing your results. I’m really glad to hear that it worked for you!
Your feedback is particularly valuable because you’ve confirmed two working solutions:
Switching on the Polar Verity Sense before powering up the other Bluetooth devices.
Using the Zwift Companion App (ZCA) as a Bluetooth bridge.
The most interesting detail is that, with firmware 2.x, the startup order didn’t matter, whereas after the firmware update, it appears to make a difference.
This strengthens our suspicion that the newer firmware may have introduced a Bluetooth connection management issue, although we still need more testing to confirm the exact cause.
Could you please confirm whether your Polar Verity Sense is currently running firmware 3.0.16?
It would also be interesting to know whether the connection remains stable throughout a complete Zwift session, especially when using Windows 11 directly.
Regarding the COROS Heart Rate Monitor, I’d be very interested to hear about your experience if you decide to purchase one. Its ability to support three simultaneous Bluetooth connections could be particularly useful for your setup.
Thanks again for contributing to this discussion. Every additional test helps us understand the problem and hopefully find a reliable solution for other Zwift users.
Best regards,
Jordi Riu Popito
coming from 2.2.5 to 3.0.16.
With 2.2.5 there was neither a BT pairing attempt nor a connection needed from Polar device to W11. The connection was handled inside Zwift application.
Now with 3.0.16 you have to accept the pairing attempt at first before starting your ride. I will check tomorrow, if I have to do this again (accept pairing), or if the power on order is repeatable.
Hi Victor,
Thank you very much for taking the time to perform these tests and share such detailed feedback. I really appreciate your efforts!
Your comparison between firmware versions 2.2.5 and 3.0.16 is particularly interesting. The fact that Zwift previously handled the Bluetooth connection directly, without requiring Windows 11 pairing, suggests that something may have changed in the Bluetooth connection behaviour after the firmware update.
I’m glad our workaround has helped you get your Polar Verity Sense working again!
Your next test will be especially valuable. It would be great to know whether Windows requires a new Bluetooth pairing confirmation every time you start the sensor, or whether switching on the Polar Verity Sense before the other devices is enough to establish a reliable connection.
This information could help many other Zwift users experiencing the same problem.
Please keep us updated on your results, and also on your experience with the COROS heart rate monitor if you decide to try it.
Thanks again for your collaboration. This is exactly what makes the Zwift community so valuable!
Best regards,
Jordi Riu Popito
My setup worked without further issues, Polar strap on bluetooth, Trainer en cadence sensor on ANT+. So the workaround with (once) adding de Polar to windows BT is fine. Not sure why I was not able to detect it before, but that seems fixed now.
THanks for you help and patience :slight_smile:
Hi StefKe,
That’s excellent news! I’m really glad to hear that your Polar Verity Sense is now working correctly during your Zwift sessions.
Thank you very much for taking the time to test everything and share your results with us.
It’s particularly useful to know that your setup works with the Polar connected via Bluetooth and your trainer and cadence sensor connected via ANT+.
Your experience confirms that pairing the Polar with Windows Bluetooth first can be an effective workaround, although the exact cause of the original connection issue remains unclear.
Hopefully, this information will help other Zwift users experiencing similar problems with firmware 3.0.16.
Thanks again for your cooperation and detailed feedback. Enjoy your rides!
Best regards,
Jordi Riu Popito
Did some rides this week. Even if connecting PVS at first, somehow it was not found by zwift. Maybe startup entry for zwift launcher needs to be removed.
For my setup connecting PVS via ANT+ was rocksolid. No special order needed.
Hi Victor,
Thanks for the update and for taking the time to run these tests.
It’s interesting that ANT+ is completely stable on your system, while Bluetooth remains unreliable even when switching on the Polar Verity Sense first.
In my case, I previously had trouble detecting the Verity Sense via ANT+, although my Polar H10 worked correctly.
Could you please confirm whether you’re using a USB ANT+ dongle and, if so, which brand and model?
That would help us compare our setups and understand whether the problem is related to firmware 3.0.16, Bluetooth connectivity, or the ANT+ adapter.
Thanks again for your help!
Best regards, Jordi
Things turned bad, when zwift released new client version with video. two releases prior ant connection was reliable in my setup. now its not, lots of dropouts.
i tested polar oh1 hr, same behaviour as verity sense, only visible on first try, no reliable connection.
i tested my garmin epix watch sending hr, that worked for zwift, was not able to connect to headwind in parallel. sidenote, the polar hr sense and oh1 are4 usable with headwind while not visible to zwift pc.
to me its not predictable, what is the root cause. i remember when zwift play occured, i had the same trouble of unstable bt and ant connections. i bought two direct connects to get rid of bt and ant connection to my kickr trainer. i ordered wahoo tickr fit to substitute my polar varety sense (will use it only for outdoor rides). my best guess is, that zwift broke their bt implementation, because both polar hr sensors work as before on debian with nebrain zwift (zca) or gititwhileitshot zwift (direct wine bt/ant implementation). but both linux implementations suffer on zwift video, but thats another story.
so hopefully someone at zhq wakes up and repairs their bt implementation.
zwift paincave:
my setup: w11 pc with dualboot w11/debian both exclusively for zwift. nvidia 4070, 2 ant dongles (no special brand), tp link bt usb stick, zwift play, wahoo kickr 5 with direct connect, headwind, climb, 2 bt headsets, cadence sensor bontrager duo tap s, polar verity sense.
gf setup: atv 4k, kickr 5 with direct connect, polar oh1, elite sterzo
I experienced the same trouble on Windows 11 with Zwift and Polar Verity Sense as everyone else here and was already about sending back the device.
Now I figured out what at least solved the issues for me:
It seems the sensor is getting registered again on any single start of Zwift. I have not found a way yet to have the Sensor consistenly registered but it takes just a few seconds on each start if you follow the right steps.
This way at least it’s now registering well anytime I start Zwift.
It showed that the key problem was the timing of pressing buttons. Once you are in the device secion of Zwift, just wait until the Windows message automatically pops up asking for permission to register the Polar Verity Sense. Do not press any other button in Zwift before you confirmed that Windows Message with OK.
I noticed that sometimes this message is hidden behind the Zwift-Window or other Application-Windows which are open. In that case just scroll through the open Apps with ALT+Tabulator until you find it. Then press OK immediately.
In the background the Windows registering will be processed and for unknown reason it takes a while. But please be patient. It normally come back, saying registration was successfull. In that case you can then (and only then!) also press “Continue” in the message popping up in Zwift. Even if doesn’t come back it can be succesful, though. This is the case when the BPM rate becomes visible in Zwift. Later on you will notice that Windows message box saying that registration was successful.
Sometimes it may say registration was not successfull. Don’t worry! I assume that the reason is, that it took to long to press the OK button. It is very important to locate that Windows box asking for confirmation quick enough. If it didn’t work just out the first time, just request in the Zwift Sensor settings again a search for the Sensor, select Polar Verity Sense once it is shown there, and in the background Windows the request is being triggered. Again: Just wait for the Windows Message Box to return with success message.
When in Zwift not only the Sensor Connection is established but also the BPM rate is shown, the connection remains stable.
But you must always press the OK button first in Windows - otherwise it well never going to work (at least not in my case).
Happy Zwifting
Mark
Polar Verity Sense – Windows 11 Bluetooth connection: New findings and possible workarounds
Hi @V.Ampiro_del_Mar, @shooj, and Mark Wehrmann,
I would like to share some additional findings regarding the Polar Verity Sense Bluetooth connection issue with Zwift on Windows 11.
1. My experience
After updating my Polar Verity Sense to firmware 3.0.16, I experienced problems with Zwift detecting the sensor but not receiving heart-rate data correctly.
After several tests, I managed to restore the connection using this procedure:
  1. Completely close Zwift.
  2. Disable Bluetooth on other nearby devices, particularly smartphones, to prevent possible interference.
  3. Turn on the Polar Verity Sense in heart-rate mode.
  4. Open Windows 11 Bluetooth settings.
  5. Pair the Polar Verity Sense directly with Windows.
  6. Once pairing is completed, launch Zwift.
  7. Select the Polar Verity Sense as the heart-rate monitor.
This procedure worked on my system.
2. Victor’s experience
Victor has reported that pairing the device with Windows first does not resolve the issue on his computer.
Zwift detects the sensor, but the connection remains stuck at “Connecting”.
Interestingly, his Wahoo TICKR FIT connects successfully, suggesting that this issue may be specific to the interaction between Zwift, Windows Bluetooth and the Polar Verity Sense.
3. Mark Wehrmann’s new findings
Mark has now reported another possible workaround.
According to his tests, the timing of the Windows Bluetooth authorization prompt is extremely important.
When Zwift requests permission to register the Polar Verity Sense, the user must accept the Windows authorization prompt BEFORE pressing any other button in Zwift.
Sometimes this Windows dialog is hidden behind Zwift, so using ALT+TAB may be necessary to locate it.
Mark reports that once authorization is completed correctly and heart-rate data appears in Zwift, the connection remains stable.
Thank you, Mark, for sharing this discovery!
4. A question for the Zwift development team
@shooj, these findings suggest that the Bluetooth authorization and registration sequence may play an important role in this issue.
Could the Zwift development team investigate whether the Bluetooth security or pairing changes associated with Polar Verity Sense firmware 3.0.16 could be affecting the connection process in Windows 11?
We now have two different procedures that have worked for different users, but neither appears to be a universal solution.
It would be very helpful to identify the underlying cause and establish a reliable connection procedure for everyone.
Thank you to Victor, Mark and the Zwift team for continuing to investigate this issue.
Best regards,
Jordi_Riu_Popito
