My polar at first seemed to play well with Zwift and then it got iffy and inconsistent.
I put it down to perhaps salt ingress or something wrong with the polar 10. I switched to a garmin heart strap and thus far working very well. Saying there are two possible things going on…
degraded heart monitor OR comms issues. Seeing as I had none at the start and HRMs by this time are pretty standard fare, I suspect the former rather than the latter
Has to be a comms issue, because I have 2 HRM that won’t connect to Zwift anymore, my Polar H10 and my generic from my commercial Horizon treadmill that used to work with Zwift
Well after the latest zwift update, I had to manually calibrate the kickercore2, to get it to pass data again with the zwift app. It appears that the comms between the two were frozen or something…
I imagine you have removed the batteries from the HRMS, and reset them with polar app directly etc…
I just have a problem with the H10 no Bluetooth mouse, no bluetooth speaker, not even with the Kickr Core 2 or the click buttons it really just the H10. And wlan/bluetooth module i already replaced to be sure its not the module.
Some months ago there was discussions about new EU requirements regarding privacy and HRMs. I have seen pop-ups from Zwift that require you to give permission to Zwift in order connect to your H10. If you missed this or replied improperly that could be an issue. Some Zwifters said they needed to connect their H9/10 to the Polar Flow app and upgrade the firmware that was compliant with the new EU regulations. We haven’t had problems with either of ours. Other than seeing the Zwift popup for both requiring permission to allow Zwift to use the data.
With Zwift using location, there shouldn’t be a need to ask for permission, it should be done geographically one would think. Doesn’t explain why my Horizon treadmill HRM isn’t seen anymore for running,..
I don’t think your location matters to the manufacturers that are adding Bluetooth encryption to HRMs. They just turn it on in the firmware and they’re done thinking about it.
As others have noted already, Polar updated their firmware for the H10 to meet data privacy regulations required by the European Union. Even if you don’t live in an EU member state, you should allow consent for the HRM to work correctly.
