Zwift running on my PC no longer can find Zwift companion. After rebooting and restarting apps a few times with my new IPhone I tried with an older Pixel and it didn’t work with that either.
Has anyone else seen this problem?
Did you try to restart your internet router and modem
Thanks, it’s working now. What problem does a modem and router reboot fix?
I am not a network guy so I don’t know the details.
But I know it resolves a lot of issues.
I had the same issue once. In order to synchronize with Zwift, the phone which runs companion app and device which runs Zwift should be on the same wi-fi network. If you accidentally connect device running Zwift and phone to networks with different names within your home, or your phone runs on over-the-air data instead of your home wi-fi, you will lose synchronization of companion app with Zwift.
