Pairing IPhone 7+
I am having considerable issues with my 7+. I can see all my sensors on Wahoo app. Kicker. Climb. Hr & cadence but will not show up in my blue tooth setting on my phone consistently or after a period of time that is usually unreasonable. I am thinking this is a IPhone 7+ problem? Thoughts
Make sure you are not running the Wahoo app at the same time as Zwift, Bluetooth only allows one connection at a time
Also make sure you disconnect your trainer and sensors from ALL devices and apps (including your phone) before starting Zwift.
Paul. Thanks. What do you mean by "not running the Wahoo ap?
I open the ap to make sure the everything is running and then open my zwift. Are you suggesting I don’t open the ap at all before opening zwift?
You need to completely close the Wahoo App before starting Zwift, it might be holding the connection to the sensor(s) so they cannot connect to Zwift.
Again Bluetooth only allows one connection to any device or app at a time.
