Pairing Garmin heart rate monitor with Zwift
(Anne Rainville) #1
Is it possible to pair my Garmin heart rate monitor that came with Garmin Forerunner 310 to Zwift, or at least sync the data?
(Kacper Romanowski) #2
Anne,
Garmin heart rate monitor uses ANT+ protocol, so all you need is ANT+ usb dongle that connects with your computer and you will be able to pair heart rate strap with Zwift.
(Anne Rainville) #3
Hi Kacper, Thanks for the advice. So I’ve plugged in the ANT+ usb dongle, strapped on the heart rate monitor, opened zwift and searched for heart rate, but nothing appears. Is there something else I should do?
(Anne Rainville) #4
And of course as soon as I sent that it started working.  Thank you!
(W oetherman) #5
Can the Garmin 920 XT heart rate monitor connect without an ant by just using my iPhone?
Teresa
(David R) #6
What can i do to pair my garmin 920xt strap to zwift?
(Paul Allen) #7
David,
What would be the point of pairing the 920xt to Zwift? It doesn’t have a built in HR monitor and you cannot use it as a bridge. Not sure what you are trying to accomplish wanting to do it.
(Leroy Kulczynski) #8
I’m guessing they want to use the actual strap not the watch. I am having same issue, cannot connect hrt strap from garmin to Zwift. I am using ant+. Any help appreciated.
(Paul Allen) #9
Leroy,
More info is needed to assist you.
(Mahmoud Qutub) #10
I’m struggling to connect my Garmin HR monitor with Zwift on the Apple TV. I’ve got the Wahoo Vortex trainer which is syncing just fine with Zwift except for HR. I understand from reading the above that I need an ANT+ dongle in order to sync? Is that correct?  If so, which ANT+ do you recommend and secondly where does it go if I’m connecting straight into Apple TV without a laptop or any other device? Thanks.
(Paul Allen) #11
Mahmoud Qutub,
An ANT+ dongle will not work in an ATV. You will either need to get a HRM that broadcast in Bluetooth (or duel band) like the Wahoo Tickr or you will need something like CABLE to bridge the ANT+ to your ATV.
(Mahmoud Qutub) #12
Thanks, Paul. That’s helpful.
Will this one work? https://www.powertap.com/product/powertap-powercal
