Pacer Partner Bug
Hi all
Twice today I experienced an issue of being sent off in another direction with Miguel on the London Classique route. The first happen after an hour with Miguel. Logged back in and was sent off in another direction after 25mins with him.
Wondering if others have experienced this since the latest update?
Do you have virtual steering and if so, did you inadvertently select a turn you shouldn’t have at some crossroads you came across?
Hi John
I just started the steering ‘path’ a couple of weeks ago. You maybe right. Although I didn’t select to turn right instead of left where Miguel and the group headed, but if I twitched my bars and that causes it, that’d be the answer. I’ll be mindful now.
Appreciate your help.
If you have a steering device such as an Elite Sterzo or JetBlack steering block, you should find a Zwift setting called Intersection Controls and toggle it. That will permit steering but disable navigation by steering.
Of course.. that disables navigation by steering :slight_smile:
Thank you Paul. I’ll do that.
