Pace groups
Hi!
I’m currently in pace group D. I weigh in on about 97 kg and my FTP is now 229 w. Is pace group simply a result of dividing FTP with weight? 229÷97 roughly equals 2,36 w/kg. The only way to go is either to or both…
a) lose weight
b) increase FTP?
Regards from Sweden
Pace Group is determined by W/kg of either your zFTP (not FTP!) or zMAP values. You can find the Watts for those variables in the Fitness section of your profile on my.zwift.com. Then you divide by your weight, but not just your current weight (unless it has remained constant). It uses the average of the weights you were at the time you set your 3, 5, 12, and 20 minute PRs in the last 90 days. Then you compare those W/kg numbers to the chart on this page:
Thanks a lot. I found it.:smiley:
Zwift is pretty hard work because of the dynamics it uses at 97kg so depending on your age you will find it pretty hard to get out of D cat.
Train hard, lose some weight and aim to become a top D Cat rider, you don’t want to get into C Cat you will get smashed.
You really should delete the personal information from your post!
Age 57 at that weight you are D Cat all the way.
Pretty much if you are not on drugs, not weight doping and have an accurate power source you will find yourself in D Cat.
Every time you reply to one of these comments via email, it’s including your email signature. You can edit the comments to remove that info if you want.
Med vänlig hälsning
Pär Andersson
(Removed E-mail)
I can see both sides when it comes to the weight doping.
The Zwift Physics is unfortunately all wrong so people are doping to level the playing field.
There are many folks (both older and younger) outside of D cat that are not on drugs or weight doping with an accurate power source.
A rider at that weight who is in the middle of the bell curve for power will quite likely be in D. There are many legit riders above that level, but D would be a perfectly normal place to find them.
Prove it, you can’t.
No point arguing about it, I can simply change my rider weight from 95kg to 65kg tomorrow and ride any Cat I want to.
Yes, I understand that. The statement I was responding to seemed more general than that.
Correct, this is where Zwift needs to be running some AI and looking at the bell curve. It has enough riders of exactly the same age and weight to start doing comparisons and it knows what power source you are using. Sure there will be some outliers but statistics don’t lie.
Prove what? Again, the OP for sure is D cat with their power and weight, no arguments there. But there are many folks who have accurate power, are not doping etc, both older and younger who are well above D category power.
Maybe I’m not understanding the statement. Either way yes, OP would be D cat.
This is not true!
You can make your way to C, no doubt. In am 66 now, 187 cm and 91.5 - 92 kg, never cheating, riding indoor in winter only. This winter is the first one I stay in D - after 5 years of starting in D and coming to (bottom) C later.
Ride on!
