Outddor ride not seen in companion app
Hello All,
soemetimes my outdoor rides are not showing up in the companion app recorded with the wahoo elment. I tried already to doconnect an connect wahoo to zwift but not working. Does somebody have have an idea what can be the reason?
Heiko
I am not familiar with the Wahoo devices, but I know there can be issues with Garmin devices if you record the activity under an activity type that isn’t recognized by Zwift. If you record something as a specific type of ride, say a gravel ride, on your device, it may not transfer to Zwift properly since it is looking for an identifier like “ride”. Disclaimer, I am just guessing a little at this since I don’t know the exact situation, but might be worth looking into that angle.
This needs Wahoo to be reconnected to Zwift, so that anything in Wahoo should sync through to Zwift.
Do this in the Zwift Companion app. it is mentioned here:
You could potentially do the hack at the end of that topic. :face_with_peeking_eye:
I had a run on Friday recorded on the Wahoo App that uploaded fine to Zwift.
Saturday’s long ride did not.
In the Zwift Companion app, the Wahoo check was unchecked. I reauthenticated and my ride uploaded to Zwift.
As far as I know, nothing changed to cause Wahoo to not be authenticated.
Faced the Same Problem at the weekend with 2 outdoor rides. Reconnect of wahoo in the companion App did not work. Any Other recommendation?
