Hello Zwifters,
I wanted to share some insights from an experiment I conducted to better understand how power distribution affects ride times in Zwift. During some rides, I noticed that certain riders could complete courses faster despite having lower average power and lower watts per kilogram. This intriguing observation led me to investigate what might be happening and how power distribution could influence performance.
To dive deeper, I downloaded a Zwift ride’s .fit file containing power, speed, and elevation data. Using this information, I estimated the drag and rolling resistance coefficients (weight with bike = 87.61159 kg (my weight without bike is 81.6 kg (180 lb), so tron bike is about 6kg, Roll = 0.0025, Drag = 0.3086613, free fall = 9.81, air density = 1.225 (all in metric units). These parameters allowed me to solve the differential equations of bike motion and replicate Zwift’s speed outputs under various power strategies.
With the model calibrated, I focused on a simplified elevation profile—a single trapezoidal hill with a 5% grade (total length 6 km). The goal was to find the shortest travel time achievable while maintaining the same total energy expenditure as a constant 200W effort. Here’s what I learned:
- Start Strong to Reach Cruising Speed: At the beginning of the ride, applying as much power as possible helps quickly overcome inertia and achieve a stable cruising speed. This initial burst is energy-efficient and pays dividends over the course of the ride.
- Rest on Downhills: When descending, gravity does much of the work. It’s often more efficient to reduce power output significantly or even coast, letting momentum carry you forward. This strategy conserves energy for more demanding sections of the course.
- Attack the Uphills: On inclines, applying maximal sustainable power is key. Uphill sections disproportionately affect overall travel time, so maximizing effort here yields significant time savings. Importantly, don’t ease off immediately when the grade flattens—continue pushing until you regain cruising speed.
This might be obvious to more seasoned Zwift riders, but I was surprised to learn that easing off immediately when the grade flattens is a bad strategy, as it is better to keep pushing until you reach cruising speed. Pushing harder on climbs and maintaining the effort through the transition to flatter terrain until cruising speed is reached seems to be the key for optimal energy distribution.
In this example, it takes 710 sec to finish the course with a constant 200W power, but with optimal power distribution the same exact course can be finished in 588 sec (2 min difference) using the same amount of energy. This explains how riders with lower average power can sometimes outperform those with higher average power but suboptimal distribution.
Power decomposition showing contribution of drag, gravity and roll.
The effect of drafting is not included in this analysis, which is the key in races.Also this is a numerical simulation that models power profiles as piecewise linear with 31 knots (i.e., 200 m between knots), which might lead to some discretization errors.
I plan to refine this analysis by testing more complex elevation profiles and more flexible power distribution models.
Ride On!
Alex
