Only one connection
I suudenly can only pair only the controls or my trainer, but not the two together. I use the zwift companion app. On the zwift screen one out two stays on “connecting” mode. the only thing that has changed was a windows update, but I don’t knwow if that is the reason. I’ve tried everything, but no succes so far
Not sure if this helps, but when I had Bluetooth problems (disconnects) on my Mac, I tried pairing through my phone and the companion app. It has been rock solid ever since.
Shut down Zwift, run the Companion app, go to the Equipment menu, and see if the controls show up there, or if any firmware updates are offered for the controls. You did not mention which controls you have, but Ride and Click V2 have always been one connection for both (one is bridged through the other) and Play controllers started out as two separate Bluetooth connections, but a firmware update was released to make them bridged as well.
I recommend contacting support if you’re not able to resolve it on the Equipment menu, assuming the controls are fully charged, or have fresh batteries if it’s Click V2.
Same
