NYC choppy video after passing the south bridge in Central Park KOM Arch
I observe this from about a month the video starts to be visibly choppy after passing that segment. Video is not allowed to attach but I add a photo of the area.
The effect persists till the end of the ride
What are the specs of the device that you’re running Zwift on?
It might be worth uploading the log file(s) to TrainerDX (used to be called Zwiftalizer).
I have issues in new York also in the bridge area. Starts to lag to the point where you get 1 frame every 2 or 3 seconds sometimes even longer. I just ride thru it and eventally after about 3-5 mins it stabilizes back to normal. Apple TV 4k Gen 2
I’ve never seen that on my ATV 4k 1st gen on the NY bridges.
I’m not denying you’re seeing it, but I’m wondering whether you always force-close Zwift after each riding session. If you leave it always running in the background then weird glitches can happen.
I saw stuttering on the NY KOM Reverse for the first time ever on my iPad Pro a couple of rides back (after the NY expansion), so I do think there’s some kind of performance issue around certain spots in NY depending on your route perhaps?
Yes I force close always. Lately even a restart of the apple TV as my Kickr Core v1 with cog wont connect properly unless i do. To clear up any confusion I may have added I should have been more specific in which bridge. I have this issure on the New Bridge 3% one that has come with the lastest routes. Was the last long route on the last zwift tour.
