Not running on W10 tablet
Hello,
I tried to install the software on the surf tab duo w1 and got this window
Try disabling your anti-virus software, in case that’s blocking it.
Thanks, but that didn’t help.
-------- Originalnachricht --------
Hold on, a Surface Duo? That’s got an Arm processor and not Intel. So Zwift for Windows isn’t going to run on it.
It has a Intel atom x5-Z8300 (up to 1.84 GHz quad core) and 2 GB RAM.
Ok, so it’s not a Surface Duo then?
Well Windows certainly doesn’t like the type of binary that you’re trying to install, which is what the 216 code indicates.
It’s not a 32-bit version of Windows, is it?
That’s the information I got on specs.
Das Billig-Teil hat nicht annhähernd die Leistungsfähigkeit, die Zwift zum Ausführen des Spiels braucht.
english: This device has not the ability to run zwift.
Aha! Sorry, I incorrectly assumed that “Surf Tab” was short for “Surface Tablet”.
In theory it looks like the installer should run, but as Ben said that’s a very low-power CPU and the graphics are similarly likely to struggle anyway with Zwift.
You could raise a support ticket with Zwift about the installer failing, but I’ve got a feeling that they’ll tell you it doesn’t meet the minimum spec for Zwift.
Zwift says, at least 8GB RAM and a Core 2 Duo.
This device has 2GB and a Intel Atom.
I really wonder, how even the OS is running on such a ***** device.
Get yourself a used gaming PC with like i5-4xxx, 8GB RAM, a small SSD and a Nvidia GPU like 750/760 or 9xx. Hook that up to a big TV.
