Bike creaks while doing an off the saddle interval on my on wheel trainer, what could be the problem? Help is appreciated. TIA
Could be all sorts of things, I suppose. I’d start with checking your quick-release to make sure it is tight enough. You might also try putting just a small amount of grease on the dropouts to help, also. It might also be that your bike isn’t in the trainer tightly enough, so you might check that also.
