Noble pro elite e8ix Cadence Display on IPad Zwift
Thank-you for lending me your ears….
I’m having an issue display/seeing my cadence on the noblepro elite E8ix. I’m using the iPad platform of Zwift Run. The run, and cadence are shown as connected with green ticks. Yet on every run, I’m not getting a cadence reading, just the speed.
has anyone else experienced something like this? Is it normal?
I should add, I’ve had numerous problems already with the treadmill. -screen issues mainly.
Thanks in advance
Adam
@Stuart.Middlecoate may be able to answer this…
Hi Adam.
Is the cadence showing on the console either connected or not connected to Zwift?
Also to clarify you’re not bridging connection via Kinni?
And finally… have you tried it with zwift running on a different device?
Hi Stuart,
There’s no native cadence displayed on the Noblepro elite e8ix itself. It has the inbuilt Kinni app on it. I use the kinni app on my iPad as opposed to the inbuilt app. - on kinni the treadmill card and cadence card are both connected to noblepro. I can’t see where cadence is displayed on the kinni screen whilst running. - or it’s not reporting it correctly.
I’ve tried using kinni on 2 separate IPads, and also Zwift I’ve used on 2 different devices.
I’ve tried using the cast selection in kinni.
Feels like yet another fault with the treadmill! - this is my second treadmill and 3rd screen in a month believe it or not!
Adam
