Today, 24 September 2026, I got Zwift (sort of) working under Steam on my Linux distro (PCLinusOS).
One quirk is that I have to run the installer each time I want to start it and go through the install+update process before it runs. I also can’t get my sensors connected. It can’t detect my bluetooth dongle but did pick up my ant+ dongle.
If the computer I installed it on was in the same room as my bike it might have been able to detect my power meter and speed/cadence sensors but I can’t guarantee that.
With a bit of cooperation between zwift and steam developers it should be possible to get everything working.
To get it working I added the Zwift installer as a non steam application. Changed it’s preferences to use Proton experimental then ran it. I was expecting nothing to happen and was very surprised when the installation process not only started but completed and Zwift started up.
It being fall here and ZRL Round 2 coming up I booted into the Zwift-only Windows machine… but Discord doesn’t connect after updating, neither will Steam, Zwift did update, but then bluetooth doesn’t work so I can’t connect the Zwift controllers directly to the computer. Bluetooth was the main aspect not supported in Wine (circa last year - maybe that’s changed). Please Zwift devs, save me with a linux version (or fixes to make it work in wine), so I can just use a computer that works .
I think the answer has always been along the lines of “it takes so much energy to support things like bluetooth on mac, ios, android and windows for all the different devices out there adding linux into the mix with all its different approaches to bluetooth is a support nightmare”.
I would think that with all the different distros out there that if Zwift did try to support Linux, it would end up being a sub-set of distros and then people will still complain that their one isn’t supported.
I’m not saying I agree (I’m a linux daily driver and only have a windows pc in the corner for zwift) but I can understand the business rationale behind what it would cost vs what it would generate.
I’ve been a Linux user since the early 90s and made a nice career out of it, but I don’t think it should be a higher business priority for Zwift than a native release for Windows on ARM systems. The lack of that is a much bigger problem now and in the near future.
Please consider a native Linux desktop app for Zwift, with direct pairing through the computer’s built-in Bluetooth or an ANT+ USB dongle.
It should support smart trainers and accessories such as heart rate monitors, power meters, and cadence and speed sensors without needing a separate device to bridge the connection.
New Problem with netbrains implementation on Debian.
Zwift Companion App drops BT connection ~30 minutes and then every 5 minutes. I have to switch to flight mode and back in order to proceed. does not make fun. This behavior started some releases ago, around july. Seems to be ZCA and Linux BT conflict, on W11 ZCA ant BT connection is stable.
Will try that Proton implementaion later this week.
Sorted out the issues, fix is up on github- /Gititwhileitshott/zwift-linux
This does a clean Zwift install and avoids their launcher issue. Fixed a couple other items while testing. I did a clean CacheyOS install to ensure this linux installer worked. Let me know if you run into issues.
one problem i ran into, though, was that it only let me set 1080p – i was hoping to do 1440 or 4k. i’ve got a 5060, so it seemed like it should work. any pointers for how to fiddle with the graphics settings?
Should be fixed, the installer script is set to clear the setting at install. I tested and all the options are enabled back in the Zwift app. Also fixed the one issue out there. Oh and added some extras to help in the future.
zwift reset-resolution
Remove the resolution the installer set (backup of prefs.xml kept) so Zwift chooses its own again
zwift set-resolution [WxH]
Render at WxH, e.g. 2560x1440, or without WxH at your screen’s native resolution
If you can post the details on the integrated gpu, I can see if I can fix. So many layers and options out there its hard to ensure support for everything given WINE etc. I know it works on AMD integrated, and Nvidia dedicated GPUs. Oh and there are limits that the Zwift app has on GPU horsepower, so it could just be that.
