No hint about resistance level?
(Lance Xiang) #1
Those classic(dumb) trainer (like Elite force mag) which need manually resistance level adjustment. Any solution/plan about add a hint on screen? I mean, you can totally calculate the corresponding resistance level to the gradient. There are some roughly configuration of those trainer like how much power each level means. Or there are already a notice somewhere I ignore?
(Eric C. (Zwift HQ)) #2
Hi Lance,
Trainers with manually variable resistance are asked to put it in ONE setting (it tells you when you choose the trainer in the pairing screen). Otherwise your wattage will be off.
We may add additional levels of resistance but that would be a very long and very arduous process (as we’d need to test and make one specific to Zwift for each resistance level for each trainer that has this feature).
(Lance Xiang) #3
Hi Eric
Thank you very much! I will definitely check it out later. I know it is a huge work to add this feature. Ride on!
