I’d like to avoid buying more useless gear, so if anyone could tell me exactly what I need to start using zwift, i would really appreciate it.
I have:
a cyclops fluid trainer
power tap hub
garmin fenix 3 hr watch
zwift successfully set-up on iPad (I could use apple desktop but it’s more convenient to use iPad)
thanks for any help or suggestions
You will need an Ant+ dongle for any devices that only transmit in Ant+ (All Gamin products). You will need to get a Lightning to 30 pin adapter and a Wahoo Ant+ key to get Ant+ devices to connect to your iPad.
These links will help: https://support.zwift.com/hc/en-us/articles/205625165-What-do-I-need-to-start-using-Zwift-
http://www.titaniumgeek.com/cycling/zwift-user-manual-unofficial-running-updates/
So where does the Ant+ dongle go, if I’m using an iPad?
That is why you would need the Lightning to 30 pin adapter (Lightning into the iPad and the Wahoo Ant+ Key into the 30 pin side).
Link to the Wahoo Key: http://www.wahoofitness.com/devices/accessories/wahoo-key-16
