New setup - whine from kickr core 2 belt?
Hi all,
Having a rocky start with my new zwift setup & hoping the hive mind can help.
I don’t mind the cog clicking (I’ll get some dry lube on it soon anyway) - but there is a whine like a drone taking off, which gets more intense as I increase rpm. Have i misconfigured something?
youtube dot com/shorts/AisFzZ_dvv8?is=8Jyz4_-hn-1_D-N4
The cog is currently set to 5, but the issue is the same at any setting.
I’m also having an issue where I’m hauling butt and my avatar barely moves, but I’m not sure if that’s related. All of my bike bt connections are blue/active.
any recommendations? Thanks in advance.
Your video shows this is not normal behavior from the trainer. Assuming that none of the trainer’s moving parts are rubbing on something (looks like no) then you should contact either Wahoo or whoever you bought the trainer from and send them the video.
Thanks for such a swift reply! I bought the setup from zwift so I’ll contact them. Appreciate it.
When I got my core too it would make a noise like a bell ringing every time the flywheel did a rotation. As a pedal they would just go bing bing bang bing bing. I spent the fly wheel backwards and it seemed to have fixed it somehow and it hasn’t done it since a year later
You “spent” the flywheel? Confused.
*spin
Talk2twxt error
