New set up will it work
I am thinking about running zwift on a ipad ,with a htmi adapter to link to my larger tv. Will i be able to connect my Cycleops Magnus trainer an my Garmin heart rate monitor. And will i also be able to run the companion app on my android phone. Will everything work together?
It should be possible, with a few caveats:
  • The iPad must run iOS 13 or higher
  • The Garmin HRM must be a model that supports Bluetooth 4.0 (some older ones are ANT+ only)
  • The Android device must run Android 9.0 or higher
  • You’ll need to calibrate the trainer using the Saris app (don’t use Zwift calibration)
Use a Zwift free trial account to see if your equipment works
More details in this support document:
Thank you for the information
