Need help with set up
Hello everyone,
I just received my first Zwift hub with 8 cassettes (I ordered for the first time).
The assembly from the hub has worked flawlessly, only my chain is crooked and rubs on the next larger sprocket. This does not feel correct and I do not know what the problem is. Can anyone give me a tip on this? I have everything built according to instructions, have the same number of cassettes on the hub as on my road bike and do not come myself on the solution.
Any help I appreciate, thank you
Frank
Hi Frank and welcome to the forums!
Sounds like you might just need to adjust the rear derailleur a bit, try indexing it using the tension adjuster where the cable attaches to the derailleur.
