I have an MTB with offroad tires 26`… will it be a problem? slipping or leaving tread on the roller? and how will it slip when riding hard?
It should work as long as you install the flywheel using the proper bolt holes on the trainer. The only sure way is to test it or contact Tacx Support.
ok, thanks. and what about the width? is it enough for the 26` mtb tires?
I don’t think that will be a problem.
