Hello,
I am moving from the UK to the USA. Does anyone know if I can take my Zwift Hub trainer with me and use an adapter? Or is it better to re-purchase one in the USA?
Thank you
Hello,
Thank you
In an image of the power brick label in the DC Rainmaker review, it shows 100-240V input is supported, so it should be able to switch successfully if you use an adapter or replace the power cord that goes from the transformer to the wall. You could check the label on yours to make sure it’s the same.
Hello @Hannah_Parsons welcome to Zwift forums.
Yes, you can pack your Zwift Hub trainer with you. When you’re settled in to your new home, please contact Zwift Support and ask for a region-specific power cable with adapter for the US.
