i have installed mobile app and link app. Mobile app works ok, power is diplayed as it should be, but if i am using link app, it displays like 1200 W or 0 W.
Wifi connection in bluetooth is ok, Is there anything else i can do?
Make sure you’re pairing your trainer under Power, not Speed, which is what it looks like you’ve been doing. If you’re still having problems after that, you can submit a support ticket via bit.ly/zwiftsupport
I have exactly the same problem with a new Elite Qubo Digital Smart B+.
Seeing as you are using the app Im guessing your connecting via bluetooth as well. Are you able to pair yours by the “power” sensor?
Part of what I think is causing the issue for me, is the qubo doesnt appear in the pairing under the “power”" selection list (even though its a smart trainer), however the device does show up under the “classic trainer” device listing.
Soon as i spin the pedals the power is maxed out, same as you describe above.
Depending on what classic trainer i choose you end up with:
Generic = limit of 400w / any other elite trainer = 1200w.
