Mobile Companion App
(Julian Moore) #1
Tried the mobile App yesterday and generally very impressed.
Couple of things I noticed.
When running my Garmin and Tacx at the same time the Cadence was lower and the same on both but was showing higher on Zwift. Using a Suunto Mini Ant+ Dongle but not sure why the data is different.
Any plans to show the data in Metric also (similar to when you select U to change the units on the Laptop)?
Nice to have the data closer to hand.
Like the gestures also, nice touch.
(D W - ltb LMDGD) #2
I agree. It would be nice to have the option to see metric units on the mobile app.
(Eric C. (Zwift HQ)) #3
Hi Julian,
Do you have a paired cadence sensor?
Also, the app will eventually show whatever units you pick in game (so if you pick metric the app will display metric).
(Julian Moore) #4
Hi Eric,
Yes paired my Garmin GSC10 to Zwift.
Readings the same on the Garmin and Tacx but about 10rpm higher on Zwift.
Each time I log into Zwift to start a session it detects my Heart rate, Power and Speed Sensors but I do have to rotate the crank fro it to detect the Cadence each time. But once I do that all four show up as paired.
Regards,
Julian.
