Has anyone else had issues with missing training activities.
I have an activity on the 9th of jan ( a walk) showed as pink yet previous walks have not appeared not sure why as I haven’t changed anything .
Appreciate your input
Walks were originally being imported but they turned that off. You would have to record it as a run, though if it’s a Garmin activity you could follow up later by editing the workout type back to a walk.
Just did walk and tracked it as a run but it’s not put on Zwift I’m using my wahoo rival watch???
Hmm I have only heard about this in relation to Garmin watches, so I’m unsure if there is something different about Wahoo. Do you see the activity in the Wahoo app? Another thing to try would be disconnecting and reconnecting Wahoo from Zwift here: https://www.zwift.com/settings/connections
It finally came on but not sure if I did something different will try it out again next time , Thanks for your input ![]()
