Minor Bias display issue in companion app
I’m using the Zwift Companion app when I ride, and typically do workouts. I’m using Companion App version 3.85.0 on an iPhone 13 Pro Max running iOS 26.5.2
Steps to reproduce:
  1. Start a workout in Zwift and start the companion app
  2. In the companion app, tap the 2nd tab at the bottom until I’m in Workout mode
  3. Change the Bias to anything but 100% (example: 95%)
  4. Tap the 2nd tab twice to go into Map mode, then back to Workout mode
BUG: the displayed Bias is 100%. Note that I believe this is a display issue, since changing the Bias now updates it from the correct / previous Bias, not from 100%. In other words, hitting “+” will change it to (for example) 96%, not 101%.
