I just started using Zwift. I have done 2 runs and neither showed my mile splits when I look at the activity afterwards. Is there a way to fix this?
I’ve just checked and you’re right. They’re showing in game but not after.
Double check you’re running both the latest version of the app and also companion app.
I’ve not seen this before but then don’t regularly look at my post activity data.
How are you viewing your activity?
Are you using Zwift Companion App? If so your mile splits should be at the bottom of your activity. This is your second run mile splits.
They should also be showing at the bottom of your The at Home Cycling & Running Virtual Training App account activity reports under Running Splits
I can see his mile splits on ZCA using IPad and IPhone. What device are you using to view?
Interesting.
Android.
I am using Android too. I do see it in my activity feed if I am using my web browser. I am on the latest version of both apps also.
