Mac Computrainer not working
(stefan raab) #1
I am able to see it in the setup, but as soon as I start to ride the computrainer display goes back to calibration and then I am never able to ride.
It seems to work fine with my powertap.
Also, do I have to login and setup every time I start the app? Seems like it isn’t saving settings.
Also onetime it started working with my CT in the background behind the login screen.
(Kevin McCullough) #2
I have the same issue and would really like to know if someone has figured out the issue.
(Kevin McCullough) #3
I was having the same problem and a friend told to hit the A key while in zwift to see if the Computrainer was still the power source. It wasn’t so I repaired and it seems to work now.
(stefan raab) #4
Thanks! Hitting the “A” key worked!
(Duane Gran [Vision]) #5
I confirm the same issue. Haven’t had a chance to hit “a” to fix, but I’ll try it soon. Glad someone noticed this.
(Josh Sakofsky) #6
I am kevins friend who figured this out. You all owe me a lead out for the green jersey if you are online at the same time as me, FYI…
(Hal Kingsbury (PVC)) #7
What kind of serial adaptor are you using to connect the Mac? My Mac will see the computrainer, but does nothing once I start pedaling. Do you have to do anything to the computrainer controller to start? Please let me know and thanks.
hal.
(Kevin McCullough) #8
I use the USB to Stereo Adapter bought off the Racermate website.
(stefan raab) #9
I’m using the FTDI USB to serial adapter that came with my 10 year old CT. It has been very flaky with Zwift. Sometimes I have to select it 5 or 6 times before it actually takes it. You’ll know it’s working when you see power on the selection screen.
(Don Seib BMB) #10
Same or similar problem. Zwift see’s the computrainer in pair mode, takes a few seconds and finally shows watts and then when you join the ride it drops the resistance/power immediately. Are you hitting “a” after you join the island?
Thanks,
Don
(Don Seib BMB) #11
BTW, I’m mac mavericks with the ftdi adaptor.
(Josh Sakofsky) #12
yes, after you join the island and it shows your avatar sitting on the side of the road waiting, hit the A key to enter the screen where you can select your devices and re-select your computrainer as the power device.
(Don Seib BMB) #13
Thanks Josh, much appreciated
