Login screen constantly rotates
On opening the app it constantly rotates through 180 degrees and back, making it unusable.
Google Pixel C running Android 8.1
Can’t tell the app build version because the screen doesn’t stay still for long enough, but I downloaded it today 7th Jan.
Got the same issue.
If you go in the drop down config, you can lock the device rotation and then turn the device around, it fixed the problem for me. The camera was on the bottom but it worked…
I have the same problem…
same problem here
Thanks for the heads up everyone, looking into this issue!
Edit: We’re aware of this issue and it’s being looked into. :ride_on:
Mine is the same.
When will it be looked at?
