Companion app not connecting to live activity. it’s happened before and started working after four or five weeks and it’s back again after this latest update. I already tried deleting the app and reinstalling the app and logging in again next I’ll try resetting the router but I doubt that will work.
I’ve never had any issues with the companion app not connecting to the game session. Tell us more about your home network environment, do you use wifi nodes or signal boosters? Hard wired PC into the router? Apple TV? etc… what are you using?
If it ever works, then it’s unlikely to be a permission problem, unless the phone has had an operating system update in between the working and not-working experiences.
Can you describe everything about your network? Are there range extenders or mesh nodes involved? Rebooting the network equipment is a good thing to try especially because it’s so easy to try. If there are multiple components in the network I would reboot every one of them.
Running game for 5+ years now on iPad, companion app on Iphone from wireless router 20 feet away. Connected to old bike on kicker trainer via Bluetooth. Everything is latest update.
I did have to wipe my iPad completely might be something with A update or a setting that got changed when I reinstalled the Zwift app
If you’re using Apple devices and Companion pairing breaks completely (ie, not an intermittent problem) then local network access permission may be the problem. Usually re-installing the app will result in a prompt to allow it. This can be the issue on either of the two sides of the connection.
Aside from that, on the network side, the devices need to be on the same WiFi network, and with many routers that also means they need to be on the same band (5GHz or 2.4GHz) or it may interfere with discovery. If you have multiple WiFi networks configured on it, make sure both devices are on the same one.
all that is over my head. It’s AT&T‘s newest router about a year ago you can’t even configure or select 5G or 2.4 G anymore and configuring multiple networks on one router way over my head.
Start by checking the app permissions.
On the iPad, open the Apple Settings app, tap on Apps → Zwift and look for Local Network. Make sure that is on.
I gave it another shot today troubleshooting and before I read your last post that’s exactly what I found. For some reason when I wiped and restarted the iPad and reinstalled the Zwift app the local network button got turned off, even though it was all connected to the same network. Thanks, Paul and everyone for helping troubleshoot.
