Hello to all. Turned to LineageOS 20 with Gapps on the Samsung galaxy tab A8 (2021) and have a problem with the Zwift app - installed from google store but at the start it shows error “Data Validation Failed”
Could any help to solve the problem pls…
Potentially it’s failing a check as you are running a non supported OS.
i doubt you’ll get an answer here and probably better off contacting the developer of the OS to see if they can help.
Could be something simple like one of the folders Zwift needs to write to isn’t present.
