At the start of the week I installed to Windows 11 H26 update. On Tuesday night I went to start Zwift and the Launcher failed to load correctly. The background picture appeared offset, overlapping outside the top left corner of the Launcher box. The action buttons were missing, but the pointer acted as though it could see them, although it failed to launch Zwift. This was a repeated occurrence and led me to uninstall and reinstall Zwift from the website, which got it to run, but I missed the event start.
Thinking it was fixed I went to Zwift again yesterday and had exactly the same problem. What gives?
I have also recently updated to Windows 11 26H2 and have not seen this problem or heard of anyone else reporting it, so take this suggestion for what it’s worth…
When re-installing did you do the manual cleanup steps in this document? Reinstalling Zwift
In addition to everything in that document, you could also try deleting the WebView data in %TEMP%\..\Zwift\launcher\webview which is used by the launcher, or delete that entire launcher directory as part of your re-install process
Could try making a new Windows account, give it admin privileges, start over with a fresh install there
Shuji at Zwift HQ. Are you using a secondary screen? What you’re describing sounds like a rendering problem for secondary screens that will be fixed in the next version of the Zwift Launcher app.
Watch for an email from me in your inbox. I’ll message you offline.
Thanks @Paul_Southworth , I did do the manual cleanup but will take a look at the temp files. I don’t want to go down the route of additional accounts, at least not yet.
@shooj yes, it was indeed running on a second screen. I did disconnect it it to try it solo but that didn’t seem to do anything.
