Lap splits on the May Field running track
This is a running request I couldn’t find via search: the Zwift UI should show your splits each lap of the May Field track, much like a coach shouting 67, 67, 68 at you each time you go past.
Maybe lap progress could also be built into this like when cycling AdZ, it’s currently quite easy to miss the lines as you go round.
If the Volcano circuit and Jungle can have lap counters, why not a real lap track?
I like the idea.
In addition to the lap counter, maybe show the last 3 or 4 lap times.
{EDIT}
I suppose that people doing intervals (100m, 200m, 800m, etc) may not benefit from that, but straight 400m lap running would.
