Hola, tengo problemas para iniciar la conexión de la cinta de correr Xiaomi Kingsmith X21 con Zwift. Indica que es compatible, pero tengo dudas. Gracias
I’m afraid that treadmill is not directly compatible with Zwift. You would need an external sensor to link it to Zwift.
Try asking on the qdomyos-zwift Facebook group
I have a Kingsmith R2 Pro which has bluetooth but does not directly connect to Zwift.
You will need the Qdomyos ap to act as a treadmill bridge to connect with Zwift.
