When training “workout” the cadence goes down to 62, even if the lowest gear is used. With higher cadence the power limit is exceeded. The workout behavior is bizarre. I am using Tacx Neo.
I had a look at your account, and it looks like you’re paired with Tacx Pwr under Power and Tacx Neo under Controllable Trainer. This can cause issues. Change both to Tacx Neo, instead, and it should solve the problem.
Also, if you’re using ERG mode, note that you shouldn’t be shifting gears.
