Hi. I have the kickr and kickr climb. I have updates available so updated the kickr but i cant update the climb. Its not finding the sensor. Im on Android. Ive deleted the wahoo app and reinstalled it but no good. Ive unplugged the climb for a minute or so and still no good.
The climb works absolutely fine in game
Hi @David_Mckay4, I have no experience with the Kickr Climb so I can’t comment on your exact situation. However, sounds like you should try contacting Wahoo support, I’m sure they can help and are quite fast at responding.
From taking a peek at Wahoo’s support page it sounds like you need to close all apps that connect to your Kickr and make sure that your Kickr is on up to date firmware before you can use the Kickr to update the firmware on your Climb. I recommend checking out that article and seeing if those steps work out for you and checking in with Wahoo Support if you have trouble
I had another go today and it updated just fine without me doing anything. Must have been a glitch in the matrix. Thankyou.
