Kickr bike pro does not adjust angle in swift
I’m a bit new to this. I have a wahoo kicker bike pro, that is suppose to adjust for angle in swift. It does not.
Neither locked or unlockeglight indicators are on on my bike. I can adjust angle manually, and reset with double click on my bike. I use iPad Pro.
My erg if off in my wahoo app. I don’t see that button in the swift menu.
Is it working on some types of work outs? Somehow it worked once on a track, not sure how.
I tried everything… any ideas?
Tilt Angle Controls
  • The HCU Button: Located on the right side of the LED display unit (drive side) under the stem.
    • Single Tap: Locks or unlocks the tilt function. In locked mode, the bike ignores app incline changes and only responds to manual shifter commands. Unlocked mode is required for virtual app control.
    • Double Tap: Instantly levels the bike back to a **0% neutral flat position
      Also:** If you have trainer difficulty at 0, it does not tilt.. it tilt’s accordingly to the percentage and percentage of trainer difficulty. (i.e.: if u have trainer difficulty at 50% it only tilts 5% if grade is 10%)
This feature is disabled while doing workouts and only works in “sim” mode (free riding, non-workouts, events, etc…)
My training mode was set to max.
Is there a way to understand if it is locked or not? Like double tap, then single tap?
Provided you are in a normal ride (ie, not a workout) then when you enable the tilt-mode (from the control on the bike) then it should go up when you ride up hills. Even in ANT+ connections. I use bluetooth with mine.
In Zwift if you have trainer difficulty at 100% and the tilt function on, it should work:
https://support.wahoofitness.com/hc/en-us/articles/4407149873810-Grade-or-Tilt-Troubleshooting-KICKR-BIKE
