Well, ist the automatically incline of the treadmill possible with RUNN NPE?
No. RUNN NPE only transmits speed and incline to Zwift. You have to increase or decrease the incline with the buttons on your treadmill. You can optionally use a workout on your treadmill that changes speed and incline automatically and the RUNN NPE will transmit to Zwift but it will not match the incline of the road in Zwift.
Thank you for your quick Reply Thierry. So RUNN NPE doesnât make sense at all for our Kettler Alpha Run?
Well it makes sense if you want in Zwift comp.app or Strava statistics you have the incline that is displayed. Otherwise no
LâAlpha Run ne transmet pas directement la pente Ă Zwift ?
Ătonnamment non. Seulement la vitesse. En tout cas le mien non. Câest pour ça que jâutilise le capteur RUNN
Et en fait, ça apporte que Zwift ait la pente ?
Ca affiche juste la pente que tu donnes a ton tapis dans les statistiques de compagnon app. Ou dans strava. Quand tu cours tu ne vois rien a lâĂ©cran
Kettler Alpha Run 800 commandé, livraison prévu vendredi 30
Merci Thierry pour tous tes renseignements et ta patience !
Jâai bien reçu mon tapis aujourdâhuiâŠle jour du confinement, jâai bien anticipĂ© !!!
SacrĂ© bĂȘte. Heureusement que le livreur a Ă©tĂ© bien sympa pour mâaider Ă lâinstaller car seul il serait restĂ© dans mon garage !
Y a tâil des mises Ă jour Ă faire ? Si oui il faut procĂ©der comment ?
Hi Thierry,
Well, once more it is me with a Question.
Which Silicone spray do you use for your Alpha Run and how often do you use it?
Thank you
best regards
Hi Hans,
I use a silicone spray once a month. Usually you find it in sports stores that sell treadmills
Kettler says every 10 hours or every 2 months
Thierry
Hi Thierry,
Thank you for Information!
Best regards
If you are running a training from ZWIFT, change the Kettle automaticly his speed?
Kind regards
No, Zwift only displays the speed of the treadmill. You have to change the speed every time. On Zwift it is the same with all treadmills.The same goes for the incline, Zwift does not change it.
Thierry
Thank you for the information.
2 other questions in
1
Is the connection with zwift easy to do?
I have Android.
2
What is zwift companion
Are you happy with the kettler 800
I just have an android samsung S10 phone and the treadmill connects great.
Zwift companion is an app you use for chatting while you run or ride a bike. You can register for events or races, take screenshots and many other things.
And I am very happy with my treadmill. Fortunately for the price âŠ
