Keiser M3
(Arnaud Girard) #21
@ Eric Talley,
Could you kindly tell me the crank arm length you put in the settings of your powertap p1? 170mm? I guess it’s the same for any M3 and need this value for the same reason :slight_smile:
Best,
(Eric Talley) #22
@Arnaud Girard:
Yes, 170mm - which is what I have on my road bike.  Having tried them on both I think I am getting consistent readings on the M3, so it looks like a good comp.
(Arnaud Girard) #23
Thanks for your so prompt answer!
Best regards
(John Brown) #24
I think it would be a technology break through for the M3i to be compatible with Zwift. I love my M3i, would like for it to be compatible with Zwift or Sufferfest. All of my friends are on Zwift as i see on Strava. Sounds like there are others who would like for the M3i to be connect with Zwift.
(Rob Vaughan) #25
Can’t believe this thread still going nearly three years after my original post! In the end I bought a garmin vector pedal. Probably an expensive way of doing it but not looked back since!
(Arman Rivard) #26
I gave up. Pointed the Kaiser at the TV and watch Netflix while I ride.
