Keep logged in forever
(Feedback for Zwift on Windows)
Please add a checkbox
[x] Stay logged in on this device
Its really annoying having to re-login every couple of days.
Usually people use Zwift on their personal PC and its not a security sensitive application. So i dont really see why we are forced to re-authenticate on a regular basis.
I never have to re-login on my windows PC… there must be some reason your system is dropping the credentials? :man_shrugging:
a quick google search says you might be clearing the cache from microsoft edge as the launcher does use that to connect.
I never have to log in on my MacMini M2, which is my main Zwift computer, but my MacMini M4 often requires me to re-enter credentials.
I have to log in to just about everything Zwift again and again once every week or two or so. Same thing with PC (actually multiple PCs), Mac and the websites, and it’s been like this for years. I don’t think I have changed any relevant settings and I’m not using the Edge browser for anything else on the PC.
its a bug within the launcher or edge as I never use edge on my zwift machine and I have to log in every now and then
My Windows machine remains logged in for months at a time. My occasional use of a Mac often requires login, but that’s after probably a week or more of non-use. I’m unsure how they are caching authentication sessions on the backend, maybe that’s by design :man_shrugging: which would not be a shock.
Hey @Marius_Rady , I had a similar issue in the past, and I found that deleting the perfs folder helped to reset the issue. You can locate the perfs folder at the locations below:
  • Windows: C:\Users\YOUR_USERNAME\AppData\Local\Zwift
  • Mac: Documents/Zwift/
Note: Deleting this folder will remove your account and previous device connections so you will need to login and connect your devices manually the first time you enter back into Zwift.
Let me know if this doesn’t help, and I’ll ask our team to look into it :right_facing_fist:
There was no prefs folder, but a prefs file. I deleted it and will see if it helps.
Thanks!
