My jetblack victory arrived yesterday and i followed the instruction videos, if you’ve watched the videos you’ll see that after you place your bike on the trainer, you turn your pedals to check for clicks so you can line up the cog, the flywheel is so stiff, I can barely move it, even with the bike off the trainer it barely moves, has anyone else had this issue and maybe found a solution, I emailed customer support, I hope to hear back on Monday
Hi, yes, I’ve tried it plugged and unplugged, the firmware it shipped with and then the updated firmware and it’s still the same, there’s no way you could train on it, it would pull the legs of you
Don’t ask me how but it seems like it has loosened up a bit, the bigger of the flywheels doesn’t look like it’s running true but its better than what it was
You mean JetBlack customer support, or Zwift customer support? It sounds like the trainer might be faulty so if I owned it I would be asking JetBlack to send another one or offer some reasonable solution or explanation.
