Jarvis sprint wattopia
Rode twice on consecutive days and both times lost connection at the same point has anyone else had same problem?
Can you provide more details please? What do you mean by lost connection? What are you running the game on? If you mean the trainer disconnected, what is the make and model of the trainer you’re using and how are you pairing it?
Hi Paul. It was weird , the ride totally went off at the 11.5km mark on Both days , i am an experienced Zwifter and its not happening on other rides , we have no connection problems on any other devices and I have run Zwift on my Samsung tablet for the last 4 years, its the only thing I use the tablet for Mate
OK, if I’m understanding you correctly, the game is crashing. It unexpectedly quits.
Different areas of the game worlds put different demands on the hardware, so if you have marginal hardware, there are places where it’s more likely to result in a crash. Game releases also change those demands from time to time, and Zwift doesn’t always know or explain that when the release ships.
What is the model of tablet you are using?
You could also contact Zwift support and ask them to look at your game logs to understand the reason for the crash.
Since you have a tablet that is only used for Zwift, that would also make it relatively painless for you to do a factory reset of the device. That sometimes helps with mysterious problems.
Do you mean the game crashed?
Yes mate. Went completely off and when I logged back in no trace that I had been on it for those rides was found.. i have a zwift arm band and that worked perfectly, it really p#ssed me off as it was at exactly the same distance and spot. Ah well will just try another ride on Wednesday, different route .:smiling_face_with_sunglasses:
Which tablet is it?
Samsung Mate. Only use it for zwift its on my IC8 Bike
Samsung makes dozens of tablets that range from excellent to rubbish. What’s the model? I’m trying to understand if the problem is something that’s sort of reasonable given the hardware or if it’s really a surprise that should not be happening.
