Ipad pro 10.5 or 12.9
(John McCracken (GB-SCT) (WBR D)) #1
Can anyone with experience of both confirm if it makes any real difference to the zwift experience. My primary reason to purchase 1 is to make zwift more playable than my 2008 15" mac book pro.
(John McCracken (GB-SCT) (WBR D)) #2
And how do you get ant+ working ?
(Josie (Zwift HQ)) #3
Hi John,
If you want to use ANT+ with an iPad Pro, you would need to get an ANT+ bridge. We have 2 options you could use listed here.
(John McCracken (GB-SCT) (WBR D)) #4
Hi Josie
The link mentions that Resistance control for smart trainers isn’t supported over ANT+ on iOS. What does this mean in practice for a customer. I must say the options, pros and cons are unclear to me. Can you make it really clear what I need to make a new ipad pro work with my kickr snap and any limitations.
(John McCracken (GB-SCT) (WBR D)) #5
So am I right in thinking the ipad pro will connect to the kickr using Bluetooth. The Bluetooth will control the rest resistance and supports FEC so as I can calibrate within zwift. If I want to use my ant+ hrm and cadence then I need a bluetooth to Ant+ bridge such as the CABLE device ?
All correct ?
(Jason K) #6
An iPad would connect to a KICKR over BLE and handle the power and resistance. BLE is not ANT+ FE-C - these are two different wireless protocols.
If you want to use ANT+ devices (your HRM and cadence), you would need one of those bridges.
I hope this helps!
(John McCracken (GB-SCT) (WBR D)) #7
What disadvantage is there if I can only connect with BLE to the kickr and ant+ fec is not available ?
(John McCracken (GB-SCT) (WBR D)) #8
I read elsewhere that ant+ fec was the preferred mode of connecting and was planned to be supported in the future (future proof).
(Jason K) #9
BLE is only useful if your sensors connect via BLE - as you’ve found, some sensors (Garmin) don’t, so that’s a limitation. I can’t comment on ANT+ FE-C being future proof, but we have no plans to discontinue support for any protocols at this time.
@John: I’ve created an email ticket for you from this thread. Keep an eye on your inbox for updates if you have other questions.
(John McCracken (GB-SCT) (WBR D)) #10
Jason,
Can you have a look here :
https://support.zwift.com/hc/en-us/community/posts/115010724086-Kickr-snap-fec-or-not-?mobile_site=true
I still don’t understand what limitations there are if I can’t connect to the kickr with ant+ fec . Can you confirm please.
John
(John McCracken (GB-SCT) (WBR D)) #11
Can I use the lightening to USB adaptor to plug in my existing ant+ dongle ?
Alternatively will Wahoo-made ANT+ key and an Apple-made 30-Pin to lightening adaptor do the job ?
(SteveK @Cycleoptic ICC) #12
I use an 4iiii HMM with my iPad Pro  which can bridge my Garmin Ant + devices to bluetooth
(John McCracken (GB-SCT) (WBR D)) #13
Hi SteveK,
Are you using a smart trainer ? If so are you able to do a spindown in the game or do you need to disconnect the trainer from zwift and use your app ?
(SteveK @Cycleoptic ICC) #14
I haven’t found any where to do a spin down with the KURT kinetic tick and roll controlled trainer from within zwift
(Andrew Ralph) #15
Nobody answered the original question. User experience iPad pro 10.5 vs 12.9 in?
