iPad crashing mid ride🤷‍♂️
Been Zwifting for 4 years on IPad with absolutely no problems. However it has crashed twice on 2 rides losing the whole activity. Anything I can do to reduce this as gutting to get so far into a workout for it to just disappear? IOS up to date.
Which model of iPad? Try reinstalling Zwift and restarting the iPad for a start.
IPad 6th Gen 32 GB. Only use it for Zwift and Facebook viewing.
Is that the standard iPad 6th Gen, that was released in 2018, and has 2GB of RAM? Or the 6th Ven of a different model? Are you force closing the Zwift app after every use? What iOS version are you running? Does this happen in a specific world, or all worlds?
Given its age and low hardware specs, there’s always going to be some risk of memory exhaustion. Force closing the app or rebooting the tablet can help. Also if you haven’t factory-reset the device since you got it, that could help clean it up and possibly help with stability
Thanks Nigel. Standard 6th Gen. I was selecting routes that I hadn’t done on workouts but now I just take one of the 4 pre suggested routes in the hope it’s solved. 17.7.11 software version which should be latest. Do you suggest I buy the latest iPad and if so do you recommend one please?
I would start by trying to force close the app before riding each day and seeing if that helps, before you commit to an upgrade.
I would also factory reset before buying a tablet.
Any of the iPads from the last few years will be fine.
I’ve got the same issue. No issues at all since I started zwifting and now cashes constantly. I’ve updated IOS, deleted and reloaded app and shut down and restated iPad but still happening.
Did you find a solution?
Which model of iPad exactly?
The pattern I’m observing is crashes on really old Apple devices with 2GB RAM, because things like Apple TV HD model (A1625) and iPad 6th gen are both in that class. They are technically supported by Zwift but I suspect they are reaching the limits of available system resources. Those devices are all basically e-waste in 2026, though it’s quite possible Zwift will do something to make them more reliable. Nevertheless I don’t recommend using those devices for Zwift since this kind of problem seems to surface a couple times a year. Investing engineering time in them is probably a waste of effort that could be put into making the game better.
I tried everything on my 6th Gen iPad but it kept doing it so I purchased a refurbished 9th Gen and just use that for Zwift and it’s perfect. Think 6th Gen was too old . Sorry I can’t provide an easier solution.
iPad Air 2 so it’s pretty ancient!
Yeah this is likely the same problem. It’s among the oldest and weakest devices that are supposed to run the game at all, and I suspect something changed in Zwift that pushed it over the edge. Not an intentional change but it’s always a risk to use something with so little resources available. That’s the kind of tablet I give to people in homeless shelters to check their email.
subtle burn
Really not intended that way. I ask my neighbors for their old computing devices and that’s what they hand over. Perfectly good for a bit of email and YouTube, not for a 3D game.
Yeah, probably inevitable at some point that the game would evolve beyond its capability!
I’ll always remember the special times we had climbing Alpe du Zwift :sob:
