Zwift Coach is an adaptive training plan built around you and your goals. Set your goal. Coach keeps you on track. Built on the expertise of world-class coaches and powered by everything Zwift knows about how you ride.
It recommends what to do next and adjusts as you ride, rest, race, or life gets in the way. More progress. All built right into Zwift.
Set up your training plan
- You’ll need Zwift Companion to create, manage, and update your plan.
- Click the
Unlock your planposter card on the homepage, then follow the prompts toCreate Plan. - Respond to a few quick questions - there are no wrong answers.
- Your daily Coach recommendation along with pre ride information will also appear in the ZC Next Up card. In Zwift you will see Coach activity in the new Theatre Card on the homescreen.
Ride as you normally would
Follow the plan when you can. Races, group rides, outdoor rides, and rest days are all fine - the plan adapts to real life.
Keep your rides syncing
- Strava will display Zwift activities
- Outdoor activities recorded on Garmin, Wahoo, and Hammerhead devices will be factored in if your accounts are synced to Zwift.
- Zwift Coach also considers runs, including outdoor runs logged with a connected Garmin device.
- WHOOP and Oura integrations will also factor into Coach recommendations.
What to expect - Your training, your way
These features are all about training that meets you where you are. If you miss a ride, shift a workout, or take a day off everything updates to keep you on track. Know what to ride next, and why.
The adaptive training plan is an optimal route to your goal.
Just like a GPS
- It picks the best path given everything it knows about you.
- You can add stops, take detours, or ride somewhere unexpected.
- The GPS doesn’t judge, but it reroutes you to the best new path given the choices you’ve made.
Under the plan is a daily prescription focus + duration + intensity. We match that to content you enjoy. You can stay on track and meet your goal without following the exact content.
Math builds the plan - AI explains it
Your plan comes from a purpose-built training model - explained by AI. These features are grounded in proven training science: progressive overload, recovery and supercompensation, and threshold-based intensity.
- Built from Zwift’s own data - patterns from millions of real rides and workouts.
- Designed and reviewed by expert coaches who shape the methodology behind every plan.
- Individualized to you: your goal, your schedule, your fitness, and how training is actually going.
The result is consistent, explainable coaching that follows the same principles a human coach would use.
Good to know - How your plan behaves
If the plan surprises you, it may be by design.
- Available days are options, not promises - four selected days does not always mean four rides.
- Easier weeks are factored in - recovery and event prep are part of the progression.
- Missed workouts are not “made up” later - the plan adjusts the road ahead instead.
Some weeks may use less than your full weekly hours - that is normal during recovery and event weeks. If something still seems wrong, tell us in the survey!
Hours match fitness, not just availability. Daily guidance shows on Home for today.
Key steps to get started
- Make sure you are on the latest version of the Zwift Companion. Version 3.91 introduces a new Home Screen. Once you launch the app, use the Plan tab to create your training plan.
- Simplified refreshed homescreen design brings it closer to looking like a true Zwift Companion
- New post-ride state will celebrate what you just accomplished and highlight your progress
- Weekly activity graph widget broken up into 2 pages so we can go a little deeper on stats and integrations
Start with this Support article for additional details:
Zwift Plus FAQ
