Hi all. Several times over the past 3 weeks, Companion has loaded up the Running Dashboard after I have selected a Cycling activity. If I exit Companion fully and log back in, invariably it will put me back in Running mode at least once more. Any suggestions as to what is happening and how I can eliminate the issue? Sometimes I am 15 minutes into an activity before Companion syncs properly and displays the Cycling dashboard d for the selected activity.
This bug was supposedly fixed in Companion 3.44 released a couple days ago. Check for updates or check whether you have version 3.44 installed. If you go to Settings → About in the app, it should tell you which version is installed.
Thanks! Will check it out Paul.
All the best,
Craig
