I’m considering the purchase of a Dell XPS 13 laptop for a multitude of purposes but to make it cover all bases it really needs to be able to play Zwift (and WoW) at a fluid (30fps) framerate. I appreciate it may have to run at 720p to do this.
The spec’s state it has a Intel Iris Graphics (which is something I’m not very familiar with) as opposed to the usual HD xxxx. Is this going to cause me any issues with Zwift ?
Would be great if someone from Zwift could confirm that this Graphics chipset is supported and will run at least as fast as similar HD520 based systems.
Andrew the Iris 540 in that chipset is about 35% more performant than the HD 520, I run Zwift on 2 machines one is a Surface Pro 4 with the HD 520 and it runs fine so you shouldn’t have a problem at all with the Iris 540.
Thanks Mark, that gives me confidence that if Zwift addresses the Iris graphics correctly then there will be no issues. I was really looking to Zwift to confirm they do because I’ve seen issues elsewhere with “less common” cards not being correctly supported.
Btw - What resolution does the HD 520 manage to power whilst still being super smooth ?
