Incorrect watt values in LOG file
If you ride in the “Climb Portal”, the “avg watts” of the segments are initially set too low.
Example:
[14:16:06] TIMING ARCH: Player (male) passed finish line of segment 1001109 at time 287074899.76 in 266.95 seconds (avg watts 131.71).
[14:20:03] TIMING ARCH: Player (male) passed finish line of segment 1001108 at time 287075136.64 in 236.88 seconds (avg watts 139.84).
[14:23:49] TIMING ARCH: Player (male) passed finish line of segment 1001107 at time 287075362.68 in 226.03 seconds (avg watts 151.39).
[14:27:13] TIMING ARCH: Player (male) passed finish line of segment 1001106 at time 287075567.46 in 204.76 seconds (avg watts 173.83).
[14:32:06] TIMING ARCH: Player (male) passed finish line of segment 1001105 at time 287075860.35 in 292.89 seconds (avg watts 198.89).
The actual values were 149, 166 and 171 watts. The values are correct from segment 4 onwards. This is repeated for all climbs in the “Climb Portal”.
